How can I adjust the speed of my modules? - Via smart macros.
My trackpoint module sometimes drifts. - Drifting happens because the auto-calibration mechanism of the trackpoint hardware sometimes kicks in when resting a finger on the trackpoint for several seconds. This issue also affects IBM ThinkPad trackpoints, but given their position, they're not as affected by resting fingers as the UHK trackpoint module. Avoiding resting fingers on the trackpoint should make this a non-issue. Alternatively, you can map the resetTrackpoint smart macro command to any key or button to quickly recover from drifting.
The connection of my module is not reliable. - Please try to fasten the steel guides of your module. If you've already been using your UHK for a while, also clean its contacts where the modules mate with isopropyl alcohol or contact cleaner spray.
Lastly, please upgrade to the latest Agent and let it flash the newest firmware, if:
- the buttons of your modules don't work,
- the touchpad module doesn't work or keeps blinking in Agent,
- pinch-to-zoom and two-finger-scroll are not working on your touchpad.
